chrisharris
King of Bling
4,000 - God, I wonder how many I have in the Cave, lol...
Tracks bleeding over....only it is a Tascam 428/CubaseSX...any suggestions??Did I post this in the right place?dobro said:Does this sound like you?
"I recorded track one (music) in the multi-track. Then when I tried to record track two as a separate vocal track, I found that it also recorded the music with it at the same time. This keeps happening!! What can I do?"
Well, you're not alone. If you're using a standard windows soundcard (essentially, ANY Soundblaster, SBLive or compatible, Crystal Audio, ESS, Soundmax, or even some other cards from Turtle Beach) the remedy is changing the input/output settings in your Windows Mixer. Here's how...
In any version of Windows that you have:
- Dbl-click on the yellow (or grey) speaker icon located on the lower right
hand corner of your screen.
- Select Options, Properties.
- In the "Adjust Volume for" area, select Recording.
- This will show you all the devices you can record from, in the
"Show the following volume controls" window.
- Make sure all the devices have a check mark in them.
- Click on OK.
- At the bottom of each recording device, there is a check box
with "Select" to the right of it. Use this to select the recording
device that you want. (if you're recording from Line In, choose LINE. If you're recording from Mic In, choose MIC, etc)
- Make sure the recording Volume is at least half way up.
- Minimize the "Recording Control" window.
- You are ready to record.
Now, if you still have bleed, it's possible that you've either selected something like 'WAVE' for your input device, or perhaps 'Mixed Output' or 'What You Hear'. The latter settings essentially lump ALL audio fed through the soundcard into Adobe Audition. The 'Wave' setting will do exactly what is described above - cause the playback track to be recorded with the overdub track.
If you're using a more pro-level card, chances are it has it's own mixer panel (and thus, is not controlled by the Windows Mixer).
Some cards that have their own mixers: Midiman/M-Audio (Delta series, Audiophile, etc), Echo (Layla, Mona, Gina, etc), Aardvark, Lynx, Frontier Designs, MOTU (828, 2408, etc)...
SORRY...WRONG FORUM..true-eurt said:Tracks bleeding over....only it is a Tascam 428/CubaseSX...any suggestions??Did I post this in the right place?![]()
Where is the Multitrack thing located?? =/ I cant seem to find it
Once I had a friend on the phone and I was trying to explain multitrack view to him but we did not get anywhere.
So, he sent me a screen shot of his CEP and I found out that he did not have Multitrack view.
I don't know which version of CEP he was running. It could be this one:
http://icm.html.tucows.com/artist/reviews/images/cooledit2000.gif
To get to Multitrack view you need to use this ICON (look at:
http://studioangie.googlepages.com/cep )
( Don't pay attention to NEW WAVEFORM pop up window. It has nothing to do with this.
I don’t have Cool edit so I had to find other peoples pictures on the internet.)
The Icon changes to single wavform while you are working in Multitrack.
There are both icons all the time on some versions.
Double click on the audio-file will get you get to Edit View from Multitrack view as well.
If your version doesn’t have Multitrack view and you really need it then I recommend Adobe Audition 1,5.
It is (almost) the same software but with new name and new owner which means there are updates, support etc.
