AudioInsurgency
Hey everyone,
I've been recording vocals at home recently for my album and the sound guy I'm working with says that my voice just doesn't cut it. He says there's a lack of certain frequencies in my voice that allow it to cut through the mix. The main gist is that it will turn out to be a sub-par recording no matter how much work we put into it.
We're using an AT2035 condenser mic and it's the only mic we have at our disposal. We're also recording into a mini-vocal booth that amplifies frequencies below 600Hz, but we just cut those away with EQ. We used this setup before to record other artists and they sound really good.
The way that we recorded before was about 19cm away from the microphone but after some experimenting, we discovered that I sound best when I'm basically making out with the mic (like I do during live performances).
He says it feels like the range around 1-3k is lacking a bit, and my resonances are too strong in 400-1000 range. The recording booth probably amplifies those though. Multiband compression helps, with compressing lows a lot (550 hz and below), mids a medium amount, and highs above 1.94 Khz a bit, as well as an over all increase in volume.
I have attached an example of the recording that we've come up with and wanted to ask if you guys heard anything obviously wrong with my voice or with the recording.
Dry example:
https://www.dropbox.com/s/tc7tpr0gp6hbx86/The Ocean Inside Song and Vocal Raw.wav?dl=0
Mixed example:
https://www.dropbox.com/s/jynr1e6mugs6wy1/The Ocean Inside Song and Vocal Rough Mix.wav?dl=0
Mixed Solo vocal:
https://www.dropbox.com/s/bgrectyztt3bq66/The Ocean Inside Raw Vocal.wav?dl=0
Thank you all in advance!
Dry example:
Mixed example:
Mixed Solo vocal:
