T
TylerDrums109
All i know is that they happen when using two microphones withing close proximity of each other...other than that this concept has eluded me....please explain?
sound hits each mic at a diff time, this is where the problem is. normally when 2 mics are in phase, you can zoom in on the wave forum and see that both tracks will rise and fall at the same time. this makes a thick full sound... in other words its "in phase" if the mics are spaced in a way that is "out of phase" you can see, with the two wave forums created, that one will rise as one falls... so they look like they are mirroring one another. this "out of phase" recording will sound thin and less loud. the two mics actually work against one another and you lose certain frequencies. you'll need to move the mics until this is no longer an issue, or flip the phase on one of the mics to get rid of that "mirroring wave forum"
hope that helps
you know by either hearing how thin and weak it sounds. or by doing a test recording. zoom in on the wave forums that each mic has made. and look to see if the rise and fall at the same time. move the mics around until this no longer happens...another way is use head phones while placing the mics and have teh person play, move the mics untill you get a full sound. if you notice a spot where the sound is extra thin...this would be a place where your mics are out of phase... avoid that placementlol
kinda both lol. usually you can use a 3 to 1 rule. the mics should be 3 times the distance from each other as they are from the sound source
p.s. re-read my last post i edited it, i was typing to fast and missed some stuff lol
p.s. there is always more than one placement that could work, and be in phase. but there are a tone of placements that will be out of phase as well. so its really just a matter of trial and error.
