rob aylestone
Moderator
I’m really confused now. Are we adjusting parameters intended to adjust latency to create an effects? That’s just a receipt for disaster. Surely you set your system up and adjust things so the latency of the system cant be heard by you, so if you mic up a snare and hit it with the volume up a little bit but not feeding back you hear one snare hit, not two. At the point two became one, you declare a win, and store that setting never to need to adjust it. On my system the out of the box setting works. I’d have to go into the software to even tell you what the latency delay actually is, because it’s unimportant to me. Now, any delays, phasing, chorusing and other time domain effects get set on a what I hear is what I record basis.
I don’t understand why this is causing so much grief. If you keep changing the overall system settings it wrecks things.
