W
Willpower101
what pre/mixer/??? do i need to complete my multi-track setup? (inst's>delta66>gb)
So currently i have:
So far this works ok. Decent levels. Samples included below. But the mic definitely needs pre'd to eliminate hiss. Also i figure if i preamp all the instruments, we wouldn't need to be at max volume and would have a lot bigger waveforms to work with.
What piece or multiple pieces of equipment do we need in order to preamp all my instruments on separate channels before they hit the delta 66?
Or better yet, is there any sort of replacement hardware that would combine the multi-track power of the delta breakout box with preamps on ever channel and outputs on every channel?
I'm also confused about line inputs on some devices, won't that keep the same low levels the instrument naturally has?
- a delta 66 non amped pci card with a break out box - 4 mono channels in (or 2 stereo channels)
- bass, guitar, and roland digital td-3kw running in DIRECTLY, no amps. (volumes are ok, but instruments must be maxed out to get about 50% volume, mic is to low)
- shs om-450 xlr > trs mic (must record through crappy mobo sound in until i get a preamp)
- beefy quad core hackintosh with garageband (mac pro tools only supports firewire and usb on intel x86 systems. Windows pro tools doesn't pic up the levels enough to record well)
- monitoring in stereo on my home theater system
