metalhead28
Hates Raymond
All of this just reinforces my point as well as that of several others...you just need to learn your tools. I had not heard you describe what you wanted so clearly as you did when bigwillz gave you an answer......Delay... Easy right? My point was not to bash on you for not having knowledge, my point was that if you knew a little about what your tools were used for you would be able to ask a nice specific question and you'd get a nice specific answer.
The key here is to stop acting like you understand all the fundamentals because you obviously don't, if you approached it from that angle you'd probably get better advice anyway. You've just got to take the time to learn. For example: Knowing what a delay effect will do comes from using it....alot. The same can be said of every tool at your disposal. A Delay effect is a fundamental tool. Yeah, I may do heavy metal but I do in fact often use delay on lead vocals. But you wouldn't listen to me anyway would you?
Bring in the whisper track until you can barely hear it, add a little verb (or the EQ'd slapback delay). Copy and paste the hooks and you're done.
