WHARFEDALE Diamond Active 8.2 (pr):
WAS £299.00 NOW : £249.00
The Diamond 8 series is the result of over three years intensive research and development into virtually every aspect of acoustic design.
Firstly, the tweeter in all models is a 25mm textile dome, ferrofluid cooled unit powered with an ultra-strong neodymium magnet for the fastest, most accurate response we have ever achieved.
Next, the woofer cone is made from a bi-directional KEVLAR weave – self-damping in nature, reducing resonant frequencies to virtually negligible levels. The impetus for rapid movement here, is a dual layer, vented voice coil which transmits the signal information with the highest levels of accuracy. The cone is mounted on a nitrile rubber ‘Flexaural surround rim’. A profiled phase plug improves the off-axis performance to project an excellent stereo image across a wide listening area.
The Diamond 8 family has a heritage extending over twenty years and throughout has been Britain’s best-selling loudspeaker. This pattern has been repeated around the world with 5 star reviews and accolades in every country in which it has been available. As such the Diamond 8 series represents a de facto standard for sound quality and balance in a tremendous number of home stereo and A/V systems. The consistency and quality of these speaker systems across a wide variety of source materials, from Jazz to Rock, Classical, to Movie Sound Track and effects, gives a tried and proven basis for a monitor to give the professional recording and post production industry a superb reference for the creation and mixing of program material for the real world.
PRODUCT DETAILS
Application:Studio Recording
TECHNICAL SPECIFICATIONS
Type 2 WAY
Usable frequency response 45Hz-24kHz
Peak SPL @ 1m, short term IEC noise source 108dB
Sensitivity 86dB
Power Handling (Watts) 100 W
Recommended amp power 30-200W
Impedance nominal 4.
Drive Units 6.5" LF, 1" HF
System Magnetic Shielding Yes
Crossover frequency 2.2K
Input connectors combo
Input connectors (active) 1 x XLR-1/4 jack combo balanced
Active ie slew rate, distortion 10v/ micro s
Finish IRIDIUM color laminate
Dimensions of Active H x W x D (mm) 364 x 212 x 322
Weight of active unit (each kg) 8.0kg
Usable frequency range 45Hz-24kHz
Drive units 6.5" LF, 1" HF
Crossover frequency 1.9K
Output SPL ((from peak power) 108dB
Bi-amplifier power (LF/HF) 60W LF + 40W HF
Input sensitivity 0.775V RMS (0 dBu)
Amplifier system distortion at 0.1% @ 50W
Signal to noise ratio 100dB
Voltage operating range at 230V setting 205-250V
Power consumption: Idle 22W
Power consumption :Full output 130W
