D
dumass
hey...everything i record in cakewalk sonar seems to be pretty weak when i compare it to other recordings of other bands. the meters are touching red, but i have no distortion in the song yet, but it still doesnt seem like its as loud and powerful as other recordings. however, wen i make everything louder with either the 3db boost or normalizing, wen i play everything together, it seems to get fuzzy and super distorted....esp the guitars. i recorded the guitars direct....is there something that i'm doing that i shouldnt be? also, what are some good settings to get rid of that fuzz?
i use a behringer mx2004 mixer and soundblaster soundcard.....is it bc of the sound card? also, im planning on upgrading to a delta 44....so will it make it louder and more powerful? thanks a lot
bad
. most of "weak" problem caused by the source, the gears, recording technic, and how good you do it. First place to get a good strong record is from the scratch. Edit it latter won't be the same again. You may get it "strong" using compressor this and limiter that, but trust me you're gonna loose the character you have got.
