VST from Program Files (x86) not loading
  • Thread starter Thread starter jbarry
J
jbarry
I had to move my plugins from the above folder to the C:\ProgramFiles\Common Files\VST3 folder as they were no longer loading. I've been using Reaper for about 6 months and never had this problem before. Anyone else encounter this issue?
You probably need to add the new path under the 'options' - 'preferences' menus.
Yes ^^
Options/Preferences/Plug-ins/VST then 'Edit path list' to point Reaper to the VST3 folder.
However, I'm not sure what has happened in your case. Were your plug-ins working ok when they were in (x86), then suddenly stop working? Maybe Reaper lost the pointer to their file, and were you to go through the above, it would have found them.
Nor am I sure why you had to move them to a VST3 folder. Did they start working when you did this?
Yes ^^
They were working previously, thanks.
ok
some questions
1 what made you put them in a VST3 folder?
2 do they work in the VST3 folder, or are they still not working?
3 have you tried resetting the path as described above?
