pikingrin
what is this?
Couldn't find a specific answer on this one... I am using Cubase SL3.0 (with the updates if that makes a difference), and I have had a bothersome question off and on for some time. Up under the VST system link in device setup, there is a place to test everything. I can't put a screen shot up here as my recording is done on a seperate computer. Anyway, there is a check box to the top right of the popup that is titled "Self Test". Below it, there are two drop down menus titled "ASIO input" and "ASIO ouput". I am assuming that this is some kind of diagnostic test to make sure the ASIO driver is operating correctly. When I select my input and output then check the self test, it starts it's process. It says transmitting and starts counting. There are two secitons under the transmitting that say "received" and "error", and whenever it transmits the test, it adds it to the error column instead of the received. What is this all about? Is there a problem with my setup somewhere?
I can still record and playback just fine, I have always been able to, but this has always confused me. If I can give any more specific info let me know, and thank you in advance for your responses!
