G
goneracin
can a person use a y cord from say the mid and high outs of a crossover? Reason I ask is I have a good rane crossover, and it is actually way more advanced than our 2 way pa setup is. in 2 way mode, it will only cross the low/high at 190hz at the lowest, which is way to high for the subs. in 3 way mode, it has a sub xover from 50hz up. BUT then there is the mid/high crossover to deal with, again lowest point being 190 hz, and highest being 7k, so I cant just not use the mid or high out, as there will still be a hole somewhere. What Id like to do if it wont harm anything, or if it will work, is to use an xlr y cable to connect the mid and high outs from the crossover, and send them to my mains amp, and obviously use the sub out to the sub amp. I know this seems like a lot of work to go through, but id like to keep this xover, as I got a very good price on it, and it is very much expandable for future use if needed.
Thanksin advance
Thanksin advance
) is effectively the same thing as having a bi-amped (2-way) PA. If you what to tri-amp (3-way mono) you need 3 channels of amplification one for each frequency band (low, mid, hi). If you want 3 –way stereo you’ll need 6 channels of amplification. You can also go bi-amped stereo (mid/high) with a mono sub but you’ll still need at least 3 amps. Anyway, the manual will show you all the possible configurations so start there.
