SouthSIDE Glen
independentrecording.net
That kind of thing is always something one has to watch out for, but it's really not a whole lot different than the similar concerns one has with using "standard" downward compression to tame the wild hairs in the other direction. You always have to find the compromise (if there is one) between taming the dynamics and screwing the envelope.However, my comment/question is related more to the OP. Wouldn't applying upward compression to bring up some weak notes affect the overall sound envelope/decay of the piano sound? This would be something to watch out for in this instance.
Which reminds me, BTW: someone (was it phil?) asked a while back in this thread if one could simply have a zonal gain control instead of zonal compression/expansion. With a tool like Neodynum/Dynamizer (RIP
), I believe you can. Just set up the dynamic range zone you want to affect, set the ratio to 1:1, and then apply the L & R output gains as desired. This will provide a gain control without compression/expansion for just that slice of the dynamic pie. This is one additional option for those times when something like the piano decay envelope doesn't want to be messed with.G.
