J
jaz49
I posted this question on the newbie board, but thought I might try it here as well. Is it possible to damage a condenser mic if you plug it into an audio interface/mixer with the phantom power already turned on? I purchased a second hand mic from a classified forum and when it arrived I couldn't get a decent signal out of it...the output was WAY to low...even at max gain(over 60dB) on my pre with phantom power on. There's no pad on the mic. the guy I purchased it from said I may have damaged it by plugging it in with the phantom power already on. I don't think I did that, but I suppose it's possible. Would that damage the mic? I've been using an AT3035 for about a year and a half with no problems whatsoever...plenty of clean strong signal. I tried the AT mic with the same signal path as the new mic and it works fine, so it's not a problem with the pre or cable. Any ideas before I send it back? It's almost brand new.
