E
ermghoti
Its only a year or two old, and i play metal/hardcore stuff. Without a gate, especially at gig/practise volumes you always get some kinda shitty noise when you dont want it betbeen muted stabs and whatnot, which is unacceptable. Unless maybe you have perfect gear. But even Trivium/as i lay dying/etc use boss ns-2's and stuff.
*shrugs* I have used a ton of gain, really dense sound, never a problem. Like I said, if your signal volume is 100dB+, what difference does it make if you have 70dB of noise? If yo have the gate up high enough to get rid of all that, it will chop off the notes when they get down into that buzz, which is far worse (IMO) than the noise could ever be. If the noise gets unacceptable, something is wrong, and I fix it.
A year or two is plenty of time to croak a set of power tubes. I retube more or less annually. Definitely check for microphonic preamp tubes (it sounds like you've got one or more), you can swap them yourself. Then recheck your gain-staging like I suggested in my first response. You'll probably still want a retube.
Oh, and cheap preamp tubes are notoriously noisy, you may solve that problem right away.
