Dogbreath
Im an ex-spurt
Good thread...
(munching popcorn, twiddling knobs...)
You mean as in Orville Reddenbacher popping corn from Ohio, or Blue Crystal Popcorn from Northern California? If it's the later...I have a doctor's note!munching popcorn
G.
Well, I suppose it won't hurt too much to do it, but I gotta ask; if you're sending off to be mastered, why do their job for them? Unless you don't think that they will take care of that part of it, in which case I'd have to wonder why one would go with them to begin with.Oh, Glen - I meant as part of the mixing phase - before considering a mix final, more or less rape it with a limiter to see if there's anything I've missed. If so, fix it, then send it off to be mastered, and if not, send the unlimited file off to be mastered.
.But what can often happen is some of the lower amplitude stuff can be kind of muddy or whatever, and it'll make it through fairly well masked in the raw mix, but after big compression/limiting followed by makeup gain, that low level stuff winds up getting boosted and more prominent in the mix, and can stick out like a more sore-er thumb.
No, you're not crazy - not that I can tell anywayAs a guy with at least some experience mixing, but who is by NO means a pro, I read that as "sometimes, there's some low amplitude muddiness that's awfully hard to hear on a raw mix, but can be brought out by any limiting during mastering and is one of the reasons why you can't just go nuts with a limiter in mastering, because not every mix can take it very well." Ok, I'm thinking, if that's the case, then as part of the mixing process, why not pause and intentionally simulate the effect of over-limiting, to see what happens and if there's anything you're missing?
[cooking analogy understood and appreciated, edited out only for brevity]
Am I totally crazy?![]()
. I'm not sure how else I can say it other than to repeat the idea that IMHO one should not mix to anticipate the mastering engineer.Not at all. It just means that the II forces you to pick your own attack setting, which is preferable anyway.Does the lack of auto attack make the VLA II less suitable than the VLA for use in tracking?
That sums it up pretty nicely. The rub there is just how one defines the word "optimally"; that's up to the guy turning the knobs to decide. Read on...I've read your tutorial on that twice now, the first time being a while back, and it still sounds like we just move it into a range where sustain is optimally increased while avoiding clashing with or smearing the rhythm.
It sounds like we're in basic agreement.I read in another article that, if I understand it correctly, said to set release next to last (ratio being last) until the sound pumps in time with the music. Then it said to go back after setting the ratio and tweak that release setting using math (e.g., tempo is 120 and release is set to 500 ms to make a quarter note).
You seem to say at first that obvious pumping is usually bad, but then that it can be OK if it enhances the rhythm and groove of the music. Are you basically in agreement with that part of that other article then?
Here's a link to the article 3D Mixing Part 4: Compression
I think I am starting to get a pretty good handle on compression settings, except for release time.
The audible change from adjusting release time seems much more subtle to me than the other settings. ...
Just for the record:'fast/slow here is dependent quite a lot on context ..and I don't know if your optical comp is fast enough for this
That's a huge lesson right there. There's folks that have taken a lot longer that you have to figure that gem outTodays lesson? A little bit of compression goes a long way.
.Lesson two..? And exactly why I touted going easy-nay on the empo-ta stuff... but there was one thing I didn't expect. It's a 95 BPM song, but my release wound up being about 180 ms, so I didn't wind up syncing the release with the quarter note (630 ms) or the eighth note (315 ms). I was playing quite a bit of sixteenth notes though, so maybe that's why it seemed to me that I needed the faster release.
Once I started getting significant improvement over the reference track I made, it became more obvious how much release was too much or too little, but there was one thing I didn't expect. It's a 95 BPM song, but my release wound up being about 180 ms, so I didn't wind up syncing the release with the quarter note (630 ms) or the eighth note (315 ms). I was playing quite a bit of sixteenth notes though, so maybe that's why it seemed to me that I needed the faster release.
