...The guys at Talkbass keep telling me to get the DBX160X, but I'm reluctant to get an expensive (to me) compresser where I can't adjust the attack and release settings. I'd have to return the VLA to fund the DBX purchase right now, ..
A couple things here ..interesting.
I looked this up as I have a pretty good feel for the 160x as a 'fast comp but not truly as a hard peak stopper –
160A Specs :: dbx® Professional Products
They actually indicate it may be
not as fast as the VLA (..again these things may be measured and specd' differently though for all I know)
But I'm still trying to figure why they wouldn't be fast enough for bass. (I know the dbx is
sound wise. A question again might be 'Is there indeed a bit of front end spike left on it, but it is in fact doing the job –ie sounds good!
Sometimes, I'm abe to tweak stuff to where they don't happen, but I have make the compression be so light, its practically non existent..
This I didn't understand. For peaks it's high ratio, appropriate threshold. Not the same as allowing some attack but leveling out the body of the playing. A compromise might be
fast attack and very low ratio, appropriate threshold.
The dbx is fast enough for that, an industry standard known 'can't go wrong working solution. (..In general, dbx's auto mode is tough to beat.
– It will not however let you do some of the other things we like to do when
we want the option to tailor the envelope.
.. so I'm just trying to figure out of there is a way to use the VLA to get what I'm looking for. For example, using the VLA for very light compression with a slow attack and adding a cheap hard limiter between the VLA and the interface, or using a very low ratio and adding a delay for look ahead compression.
You are proposing split you signal, straight goes to the side chain, through a delay unit on the audio path side, to pick up some 'zero attack time- I've never done that.
I'm still trying to see why you'd need to though.
