NL5
Unpossible!
Nakatira said:Here`s my take on it Tim.
Man I think it sounds beautifull either way![]()
http://www.lightningmp3.com/live/file.php?fid=5105
Nice, very Nice......
myhatbroke said:No one likes mine![]()
Timothy Lawler said:jpw23 – Another good one. Verb is king!![]()
NL5 – Yeah, I’m listening more to Naka’s work on it and liking it more with each listen.
Travis – Thanks. Much appreciated.![]()
Timverb
I have those. I always thought the Blueline verb sounded pretty good. And the stereo enhancer sounds better than Ozone to me. What were your settings?jpw23 said:I used some old blue plugs on this....reverb and stereo......old directx stuff
to tell the truth.....I don't know...just moved the sliders around till I found something I likedTimothy Lawler said:I have those. I always thought the Blueline verb sounded pretty good. And the stereo enhancer sounds better than Ozone to me. What were your settings?
Tim
Hey...Finally!!! Someone that works the same I do. I knew I liked you for some reason.jpw23 said:to tell the truth.....I don't know...just moved the sliders around till I found something I liked![]()
myhatbroke said:Ok so when you record acoustic, do you do two takes of the exact same thing or do you copy and paste the same recording onto two different tracks and pan hard left and right. Or what is the technique to make it sound wide, because I noticed that acoustic recordings sound real wide.
Timothy Lawler said:mshil - thans for the info.
Nakatira - man, that's so lush and sweet it's going to make my past reverb cravings start up all over again. What did you use?
Tim
Ha… I do the same. Too much note taking kills the fun. One of the things I like about Wavelab is the master section preset list where you can save plugin combinations without getting bogged down in saving individual presets.to tell the truth.....I don't know...just moved the sliders around till I found something I liked
The mic setup I used has some width to the sound since the mic’s were 7 or so inches apart. The mic’s were recorded hard panned L and R and kept that way in the mp3. Stereo verb tends to increase the L/R differences - the Room Machine plug did a lot of that on my first run at the processing in the original post. Copying and pasting a mono guitar track, delaying one side 20 ms or so and using different EQ on each can sound good too but it’s less realistic. And as Ciro said, it can cause phase problems and that can turn into a real headache later.what is the technique to make it sound wide
Ha, that’s too funny Ray.I've not attempted because I know no subtlty
The processed one sounds like a spanish movie soundtrack like the opening creds or something. Really really sounds like it's telling a story - somewhat laidback, sunny, bright, slow day....Timothy Lawler said:I've been trying to find a way to make a close mic'd guitar sound farther away. This track was mic'd at 3 ft while sitting at my kitchen table. Then I tried to place it in a large room with the listener about 15 feet away using the Room Machine plug but I dunno... do you think it sounds at all realistic?
Estudio 19 - composer Julio Sagreras.
Here's the original file without the effect. raw file
If you run this through your arsenal of plugins and can get a realistic distance effect please tell me how you did it.
Tim
I'll try to give it a shot.
