Zaphod B
Raccoons-Be-Gone, Inc.
[this space intentionally left blank for Lt. Bob.]
So.... should I use a 10 - 100 ft-lbs torque wrench, or just an impact hammer?![]()
I use the wrench with a 3 foot 'cheater' bar on it.
ok...just heard the click...now what?![]()
you have successfully learned your first truss rod lesson.ok...just heard the click...now what?![]()
I check the relief with a marble. You let it go at the nut and it should roll back and forth between the nut and the end of the neck at least twice before settling in at the 12th fret.I heard about this thread in The Cave, so I just had to post....
Lt Bob - you forgot the bit about doing a minimum three full turns at a time before checking the relief..![]()
However, this technique only works on fretless instruments. Unless the frets are, like, really really really worn. Or if the relief is over 2", the marble will roll regardless of what's in the way.I check the relief with a marble. You let it go at the nut and it should roll back and forth between the nut and the end of the neck at least twice before settling in at the 12th fret.
well, that's what I mean. If the marble rolls then you know it's right!Or if the relief is over 2", the marble will roll regardless of what's in the way.
enjoy your new piece of wall art!
HA HA HA HA HA HAwell, that's what I mean. If the marble rolls then you know it's right!
Oh, OK, I get it!well, that's what I mean. If the marble rolls then you know it's right!
another way to check the relief is to put a mirror on one end of the neck.Oh, OK, I get it!
