jmorris
I have (2 )1/2" analog 8 track tapes I need transfered to wave files. Anyone interested.If so please let me know a price.
Thanks!
Jim
Thanks!
Jim
At the risk of sounding brash, he's trying to transfer 8 tracks, not a stereo pair. For that he'd need an 8-channel sound card to do the job right. You also need software that can record 8 channels simultaneously, which last I checked, Goldwave didn't. Reaper does, though, but in any case, he didn't say he actually had the machine - he may well just have the tapes.Heh you dont need someone to do it for you.
All you need to do is connect the line out from your tape recorder to your line input on your computer sound card then use Goldwave to record the output.
This is especially true for multitracks. I've actually been doing this kind of transfer myself, and each tape has come out around 4.7 gigabytes.Bearing in mind if you save these recordings as wave files they might be huge depending on the recording time.
Not a good idea, to be honest. When I did mine, I used 8 channels of 24/96 in raw WAV format. While Ogg is capable of supporting up to 256 channels, I have had numerous problems with its compression scheme, and also with MP3 as well.Also if you want high quality recordings, i recomend 2 recording formats.
MP3 - 320Khz 16bit Dual Channel Stereo
OGG Vorbis
You can in theory record it as 4 stereo pairs, but the machine will never play the tape at exactly the same speed every time so the tracks will gradually drift out of sync. It can be done that way by tweaking them in the workstation afterwards, but it's generally a much better idea do them all in a single pass.ok thanks
Just wondering, would it be possible to record 1 track at a time or do they need to be in syncronisation with the other 7 tracks ?
ther are plenty of people who advertise this in tape-op.
I think 20 bucks an hour is very fair. No noise reduction. I would like them run without any eq. also. That may go without saying. I'll mix them in Sonar 5 but what ever wave file should be fine.I cant remember exactly what is on the tape, the box may say but even just long wave files of each track off each tape should be fine so you dont have to determine song seperation but even that may not be a big deal for you.hey I could do this!! as long as the tapes weren't recorded with noise reduction... I could even bake them if they are sticky shed.
Maybe I could make a few bucks doing this on the side. What's a fair price? $20/hour? or should I charge per tape? Where could I advertise for a service like this??
Otari MX5050-8 -> Mackie Onyx 1620 mixer
I can do the transfer at 24-bit depth, up to 96KHz sample rate
