B
Beck
Guest
One of the most misleading and inaccurate loads of crap I've ever seen. Clearly an opportunist hoping to take advantage of the many newcomers to analog, or a noob himself.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280322938802
Seller ID: jmerghart
From the listing:
He's actually sold a few of these... very sad for the buyers trying to figure all this out.
I see more and more of this nonsense on eBay. Be careful out there.
From the listing:
Ampex, Studer, 3M, Tascam, Fostex, MCI, Quantegy
Alignment Tones on CD
All essential alignment tones conveniently on CD. Use this instead of expensive alignment tape! This auction is for an alternative to expensive and less than accurate alignment tape. The CD includes 5 minutes of each of the following tones: Just run these tones directly from your CD player at line level into your machine, monitor repro, and adjust your machine accordingly. The idea here is that you want your machine to conform to "reality standards" so that what's coming into the machine is coming out when you record and playback.
This method is a bit unconventional but it works as well as traditional old expensive alignment tape! Also included are specific instructions for the newcomer to the world of tape. 1khz at 0vu or -16 db 10khz at 0vu or -16 db 100hz at 0vu or -16 db These tones are a good alternative to the NAB EQ standard because we are now in the digital age, and you are BETTER OFF tuning your machine so that the frequency response is as FLAT as possible! Record these on the beginning of every session and master you send out so your mixing or mastering engineer can calibrate their machine to your specs. Tones are tones so don't believe the hype!
