5
506Drumma
For starters I recorded my band on a BR8
but now this promo company is putting our song on a promo cd. I need to get as powerful of a mix/master as possible in acid pro4. I send a pre-mix in stereo from the BR8 to my PC so everything is already mixed together(since it is a br8) it only has stereo outs. the problem I'm haveing is just as i get the mix exactly as I want it I can't keep the levels from cliping. I'll get them all pretty well under clipping but still sort of strong than a kick drum or bass riff or vocal run will shoot up. I try and use compression but it's all trial and error and I only figure it out as I perform a task and listen to the function to see what difference it makes in the mix. The recording it self tho was done pretty good. The bass is fat and low as I want it, the drums tho in mono are came out descent tho the snare sounds wierd prob cuz I didn't use enough mids when I sent it in, the guitars are the worst part of the mix and the vocals well you can listen to it for yourself if you want the MP3.com version was mixed in acid the garageband.com version was straight the br8. I need to accomplish a stronger mix without losing volume basically. Please Please any help would be greatly appreciated.
