Eleanor Fudd
Member
does it want a guitar cable or speaker cable or does it matter? (I haven't used an external preamp before.)
Guitar>>preamp>>interface.
Thank you.
Thank you.
Hi to all.
I have a similar problem. PRESONUS 44vsl is my audio interface and I got an ART PRO CHANNEL.
I've tried every combination of hooking those two up. TRS, XLR, Combination of those two,...
It seems that there is no way of bypassing the preamps. After that I tried to find a unity gain on 44vsl preamp but that led me to completely another set of troubles.
So, Im wondering. If I connected the preamp and interface the right way(TRS in Line input) shouldn't the preamp be inactive?
Am I getting something wrong here, or I should get another interface?
Preamp bypassed, Line in signal does not go through preamp
Correct.
Preamp gives the low mic signal a boost before it hits the next stage.
Remember for the mic pres to be bypassed and make use of the line input you need to use a 1/4" plug into the interface. The 1/4" part of the combo jack bypasses the mic preamp.
Can you explain why he might need a DI between the Line out of a mic preamp into the Line in of an interface? You kinda lost me with this
He can do a balanced connection with the right cable > XLR to 1/4"TRS
The gain for your mic will come from the ART Pro Channel rather than the interfaces internal preamp which is bypassed when using the line input. The line input on the interface does have a gain adjustment that is used to accommodate different levels of signal (-20dB to +20dB).
Quick question..... what are you attempting to achieve by using the ART Pro Channel that the preamp in your interface isn't giving you?
Your assignment is to read, starting at on or about page 9 in the ART Pro Channel Users Guide, the following paragraphs.....
Preamp Circuit
Gain Control
Gain Switch
Tube Drive/Gain Reduction Display
Preamp Output Control
How you set the Gain control on this stage will determine if your signal is clean (lower gain) or "warmed up" (higher gain).
Continue reading in the Users Manual at on or about page 16 the following paragraphs....
Master Controls
Master Output Control
VU Meter
VU Meter Switches
Where you set the Master Output depends some on how much gain you've set with the Gain and Preamp Output control in the preamp section on the ART. Try the Master Output at 0db to start and adjust the gain control on your interface for correct levels in the same manner you would for a mic when you're using the interface by itself without the ART preamp. Make sure the clip light on the interface does not illuminate frequently which would result in distortion. The Master Output on the ART and the Gain control on the interface sort of do the same thing and once you get in the ballpark with levels you may want to set the interface Gain at or around 0dB and adjust the ART Master Output to the levels you want.
Leave the EQ and Compression on the ART preamp "Bypassed" until you get the hang of setting the gain correctly.
Which channel on the Presonus are you using?
3 or 4, right? Not 1 or 2?
I ask, because you haven't mentioned it, and according to what arcaxis posted above, it matters...
