T
Tripecac
I'm using Sonar 2.1, a Delta44 for audio, and a Frontier WaveCenter PCI for MIDI, all on 98SE.
MIDI playback and recording is fine. It's stable, never hiccups.
As soon as I arm an audio track, however, playback gets erratic.
DETAILS:
- playback tempo jumps around, especially within the first couple seconds
- it continues to be erratic, as long as an audio track is armed (for recording)
- as soon as I disarm the audio track, the jumping stops (midi by itself is smooth)
- if I set the sync to "Internal", the jumping goes away (but the resulting recording speeds up and has bad glitches, so I like to keep it set to "Audio")
- changing the playback/recording master from the delta44 to the wavecenter card doesn't help
- if i disable the midi drivers, i still get erratic audio
- changing the audio latency in Sonar and/or the Delta does not help
- changing buffer sizes does not help
- i didn't have problems like this with Sonar 2.2, but I *did* have blue-screen crashes, which is what prompted me to revert to 2.1
- ASIO drivers help, but I can't use them with Sonar 2.1 (only MME-16 bit)
Any ideas on how I can get the audio to playback and record smoothly?
Thanks!
Travis
DETAILS:
Thanks!
Travis
Q.
