J
JSynthGuitarMan
Understand this: This is not a solid plan. But when I describe it, it will seem as such. This is, at this point, a completely theoretical set up and setting.
[Note: I'm a split computer/music geek, but split more toward computers and do not speak advanced sound engineer terms, this will probably need to be translated into either simple geek or plain English. Secondly, I'm definitely not even a intermediate at electrical terms. Hence the questions below regarding solar panels]
Ok, so here's the idea.
A solar powered shed/outbuilding at least 18x10, completely soundproofed.
I'm assuming that solar panels completely covering the roof will supply enough power to keep this running.
Another thing is that the room would be split with a sound proofed wall in between giving space for a control room, and within, a live room.
The main questions are, when you start with the ground up on something as bare as a shed or an outbuilding, I'm assuming you can craft far better soundproofing, and whether solar panels would be sufficient to power such an endeavor.
Thanks for bearing with me, thoughts on this theoretical endeavor?
