Well then if you're ready to make that jump, I've got something else for you to chew on ...
While guys like Southside will obsess over gear, mixing, use of gear and use of mixing etc. etc. add nausium ...
Are you willing to accept the idea that
the source itself has it's own "science" going on? Are you willing to accept the idea that there may be nothing at all wrong with the gear that you're using, or
how you're using it?
But rather ... could it be that there is something going on with source itself .... i.e. the drum set, the guitar amp ... the way the person is playing, the technique, the room accoustics, etc.
... to the point where what you
think sounds good, in the room mind you, is in some way "off?" Knowing what you might know about physics, are you willing to accept that things like air pressure in your basement / bedroom ... humidity level ... even the number of feet above sea level your recording environment is ... will
all have a huge, gigantic, tremendous effect on what is ultimately gets recorded?
Now assuming you're ready to make that stretch ... are you ready to make the assumption with me that the factors I just listed can have the deceptive and sneaky effect of
making you think that something is wrong with your gear? I'm telling you right now that a poorly-tuned head on a snare sounds frighteningly similar to a microphone that has very little high end response ... or a mic pre that has poor transient response.
So frighteningly similar, in fact, that it would be
extremely easy to make the mis-step of confusing one with the other. I'm telling you this from experience, because I know it to be true. Regardless of what "the professor" might be trying to convince you of ... a bad room sounds a LOT like a really bad mic. A set of dull strings on a bass or a guitar sound UNMISTAKENLY similar to a dull-sounding mic.
And a vocalist who has to turn his head just an inch or so to cheat and look at a lyric sheet ... sounds almost completely indestinguishable from a really shitty microphone OR a really bad room. So much so, that even the most highly disciplined ear would have a VERY tough time telling one from the other.
Are you with me? Regardless of how much of an asshole you think I am ... this is God-honest truth, if you're still following me.
