robgreen
no face
Yeah, way better. I like just about everything here more than the first mix. Two thoughts: Since you're in the business of adding presence to things, how about that reed-like instrument over on the left that comes in after the intro piano? Can you add just a bit of distortion to it or something so it's just a taste more noticeable? Also, maybe you overcooked the upper end on the vocals just a little bit. Sounds like the Aphex exciter was on 5 when 4 would have done it. Whatcha think? Or are you sick of tweaks? lol
Cool, thanks for coming back in dobro. I agree that pretty much everything is better second time around. I think there's some validity in the two tweaks you mention, so as sick as I am now of this damn song currently, I might just take a final look at them both.
With the synth you mention, I couldn't quite decide where to draw the line in terms of its presence. Without any processing it was a bit piercing, so I notched out a frequency that was contributing to that and it lost a little character. Maybe some saturation will be the answer.
Re. the vocals, the main difference between mixes 1 and 2 is that I took off a ton of processing gunk and also removed the low pass filter that was killing all the highs. I think most of the EQ-ing that's left is subtractive, but I'll take a look at whether there's anything in the saturation plug I used (that was reeled back in on mix 2 too) that's overcooking the top end.
Cheers man
