Tell me how you EQ Sweep
  • Thread starter Thread starter studiogenocide
studiogenocide
studiogenocide
Can you tell me how you EQ sweep? I've never done it! Duh! I know right?!
You send individual frequencies in minute step fashion at a rather fast pace (sweep) through whatever device you are testing.
Many test CDs will have a section with an EQ sweep, and it does it for you in a very smooth fashion...sweep up/sweep down...you just hit play.
Or....
Do you mean sweeping an EQ band on a specific track to identify issues/sweet spots?
For that I usually boost dramatically (watch your monitors)...then sweep through the band of a given frequency range...that tells me were the critical peaks are for a given track.
Here's a DAW version of that:
http://www.benvesco.com/blog/mixing/2008/fx-tips-eq-how-to-sweep-an-eq/
  • Like
Reactions: XLR
It works really well with a nice paragraphic EQ so you can see what you're doing to the EQ curve. But like Miroslav said, boost the heck out of something and "sweep" it back and forth along the frequency spectrum to find something you don't like...then cut it! Alternatively you can do a very dramatic cut and sweep it across the spectrum until it just sounds better and then raise the cut a bit (if you need to!) to find the sweet spot.
Additionally adjusting the Q can have a big effect on sweeping an EQ. A wide Q setting will boost (or cut) a lot of frequencies at once (wider bandwidth) so you can sort of hone in on the essence of the track and find where the character of it rests. While a narrow Q setting will give you a really precise means of honing in on a specific frequency.
Lastly, I find that it helps me personally (technique only) to drop the volume of the track to where I can JUST hear everything in it. It helps my ear isolate the parts (frequencies) that I feel need adjustment and I can cut them out to try and even the sound.
As always, it's usually best to do this with the whole mix running so you can get a good idea of where the track fits in relation to the other tracks.
Hope that helps! There's a TON of information on it in several places, but look up "Tweaks" home studio guide to find a lot of good explanations written in a way that's easily understandable.
I mostly use it to find problem frequencies then cut them out (as best I can). I use a parametric eq with a really narrow Q. Then I boost the heck out of it. I move it side-to-side until I hit the problem frequency and my ears start bleeding, then I cut.
Example: I recorded a live choir concert and at one point the solo mic fed back. I swept the eq until I found the feed back frequency then I cut it. It didn't totally eliminate it, but it made it listenable. :cool:
Does he not mean, (excuse me, i dont know the term for what i mean) That he wants to make a sweep on a track as an effect ,much like when you turn the LFO(?) on a synth rather than finding out where to boost and cut cirtain frequencies?
Or he could be talking about the new dance crave...the EQ Sweep. :eek::D
EQ Sweep
Here's how I sweep the eq:
