soufis
Hello...i bought from ebay a TEAC 3440...really in a good price...i had to put only a capstan belt.I oiled also the pinch roller shaft and capstan bearing..everything worked fine ...i thought then that i would have only to clean the linkage because of the sticky pinch roller syndrome but today something went wrong.
I connected the Teac in a wrong way with a dbx 228 unit.After that:
1)The Teac can play recorded music on my reels only in sync function.In play function,everything mechanically seems ok,but no sound ,no vu meters signal.
2)When i record, everything again seems ok(vu meters signal using source function,red lights on,pinch roller to the right position,capstan and reels move )...when i go back the tape, to listen the result ,(using play or even sync function),i can't hear anything..it's like i have never recorded.
I only saw the fuses on top..they seem to be ok...(i haven't checked them)...someone said to this forum that the cards need resetting...what is this exactly?
I would appreciate so much if someone knows something about this...unfortunately,there is no money available for service at the moment, in a service store....
Big THANK YOU
Big THANK YOU
