trancedental
So I removed the NEC 4570C opamps at U3 B output & U4 A & replaced them with sockets.
I changed U3 B for a NE5532P & U4 A for a Burr Brown OPA 2134, these were the only compatible opamps I had spare. But still had the same old problem with signal only when DBX NR was turned off.
I was just about to solder out & socket the U6 DBX 1252 chip & order a replacement when I decided to change out the NE5532P as I knew the the OPA 2134 was working, I then tried a LM833N for U3 B instead & switched on the DBX button & I finally got playback signal on the LED display the same as all the rest of the channels.
I've not got time to connect it up to listen but the faulty channel seems to be working! I'll check back later tonight. I'll see if either of the opamps I removed still work & maybe get replacements. I don't know yet if I might have oscillation or other problems using the substitute opamps.
