E
		ecc83
You are probably not as ancient as me Rich! The high Z mics of yesteryear were invariable specc'ed as 50k" . High z Reslos and Grampian DP4s were stock in trade for Bingo callers into 'gram' inputs on valve amplifiers.Your cable has a "balanced" 1/4" plug layout. The PortaOne doesn't need that. You just need an XLR to 1/4" TS plug. Pin 2 of the XLR to the tip of the 1/4" jack. You could tie the sleeve and ring together in the jack if you're handy with a soldering iron, just remember that you've altered the cable as it won't work if you ever try to use it in a balanced application.
The impedance matching transformer shouldn't be needed, although I don't think it will hurt anything. The impedance of the PortaOne is 10K ohms which about what most hi impedance mics are.
Of course! Specifications were even more of a mess than those today so what the ACTUAL source impedance of the mics were is anybody's guess!
I strongly suggest the OP gets a transformer, it is not so much an 'impedance changer' as a level lifter giving between 10 and nearly 20dB of 'free gain' depending on ratio and loading. They can also be useful in combating Radio Frequency Interference.
