A
acoustix
Hi- I bought a Tascam MSR-24 a few months ago, and am just now getting around to trying out the recording side of things. Yesterday, I discovered that 6 tracks out of 24 are distorted when going into the machine. The other 18 tracks are fine. The machine came with a pre-recorded tape, and the channels that don't record good (distorted) do play back what was previously recorded on the used tape clean and clear.
However, when I record on any of the 6 bad tracks, they play back distorted.
I have no idea what is wrong and if it can even be fixed as these machines have not been made in years. I don't know where to start, or if I should just use the tracks that work and forget the others. The heads look fine, and I do clean and demagnetize often. The bad tracks are 1, 3, 10, 16, 17, and 24.
Also, I do understand the difference in +4 and -10, and have the Fostex 5030 line converter, so the problem doesn't lie with the levels I'm feeding the machine. Any help from anyone who knows about this machine would be appreciated! Thanks!
