Tascam MS-16 Mods Worth It?
  • Thread starter Thread starter Broderick
B
Broderick
Hey!
Just want to know what I’m gonna get the most bang for buck with.
General recap?
Op amp change to 5532s? (I have plenty already)
Channel cards cap value changes?
Bypass caps on everything?????
I like the lofi sound of the machine already I just want it to be less noisy and more reliable across each channel. I don’t want to use +9
Tape
I’ve already re capped the power supply and re lapped/aligned the heads and bypassed the noise reduction etc.
It’s hard deciphering weather some of the suggestions from Jim Williams are over kill or not
Cheers
I have some thoughts…but no time to post detail now. So hopefully you can wait just a little bit and I’ll post again. I have a 58 with the same amp cards and some relevant guidance and thoughts. So stay tuned if that works.
That would be greatly
Appreciated thanks!
I am loving my MS-16, all original, from what I can tell and I’m not seeing or hearing a lot of noise, sounds really good to me, not lo fi but warm and accurate. Did I just get lucky? I hope it stays that way as I spend more time with it. But always very interested to hear what Corey has to say about these things! :)
Things are a bit nuts right now but I did finally find all my notes on this subject and am working on compiling them and screeding out the irrelevant.
High-level points:
The 58/MS16 amplifier circuit is pretty neat. It’s a DC servo design which eliminates almost all the coupling caps you’d normally have with a more garden variety design, and this is better. This same circuit concept carried over to the 48 as well as the ATR60 series. I don’t know if it carried all the way forward to the ATR80 series…don’t have a service manual for that. If somebody knows or can share tech docs from an ATR80 manual I’d love to know. But it’s a cool design. Not “boutique” per se, but definitely not “garden variety”. I’ve always wondered why it is I read some subjective comparisons between the sound and noise levels of the MS16 compared to the ATR60-16, that the MS16 sounds better and is quieter, but the heads are the same, and the amplifier circuitry is conceptually the same. I wonder if those impressions were machine dependent; if the ATR60 machine was not setup correctly, etc.
Some comments on Jim Williams’ work on this subject and in general: I don’t know the man at all, he is respected and his advice widely heeded. My personal opinion, and with all due respect because I’m just little people in these matters, is some of what he advises is over-the-top…over-the-top for me. Maybe not for you. I’m going to speak about this with regard to me and my opinions. My perception is that part of what categorizes a device as sounding good to Jim Williams is transparency…input equals output. And that doesn’t interest me as much. And I believe some of what he advises is in that pursuit. Again, these are entirely my opinions and perceptions. That doesn’t mean at all he’s wrong or bad, certain things just don’t strike me as coincident to what sounds “good” to me. I think the main facet in this regard is the practice of bypassing all the electrolytics with a small value film cap. For me there might be certain applications where I want to do this but only for specific circumstances. I don’t feel for me it’s necessary to do this wholesale bypass modification. Clearly a lot of people feel otherwise and maybe you do too, but for me, generally, if it is an older device with general purpose electrolytics installed, replacing the factory caps with modern low ESR parts is an improvement. I typically use “audio-grade” parts for whatever that’s worth. I’m about 50/50 wondering if I’m only paying extra for marketing hot air. But I do it anyway. The other thing I always look for is how the audio power supply rail or rails are filtered, if there are secondary filters either in the supply or local to the devices being powered and if not make a decision if there’s something to add there. Recap the power supply if it’s older. All of this is to help lower the noise floor. Lastly a general thing to look at is the value of any coupling caps, and to make sure they are not too low in value either capacitance or voltage. If the capacitance is too small that can create an audible HPF. I ran across this in a mixing console I was working years ago. The manufacturer used a lot of a certain value of cap throughout the console, probably because that helped drive the cost down with higher volume purchasing of the caps, but that cap at the input created a HPF and I don’t recall the value of the cap but I think the -3dB knee was in the low 20Hz range. Well that’s below human hearing you say…but that’s just the -3dB point. Depending on the slope of the curve that could easily encroach into audible territory and even so I don’t want an input coupling deciding every time for me that I want to filter out everything below 20-some Hz. So I increased the value so the -3dB was more like 4 or 5Hz. Understand that the higher the capacitance of an electrolytic cap comes the potential for an impact on HF performance. That’s the trade-off with an electrolytic. As well as inherent non-linearities. But with more modern caps this is much less of an issue, and the advantages of the electrolytic cap remain low cost and small packages relative to capacitance and voltage tolerance values. Now, back to the 58/MS16 amp cards, as is usually the case with 80s era Teac stuff, there’s no reason to change any values on the amp card. “They did their homework.” And sure you can go bonkers and bypass the few electrolytics in the signal path or be super obsessive like some and try and replace the electrolytics and cram polypropylene equivalents on there, which is expensive and troublesome because they are relatively giant physically compared to electrolytics, or you can just get modern low ESR ‘lytics, know it’s an improvement, and remember that countless hits and generally great sounding recordings were made using unmodified equipment with general purpose caps. So it’s a recap, and if your cards still have the original 4558 opamps on them then it might be beneficial to replace those. You mentioned 5532. I’m a fan of how they sound. But that’s me. But I can’t recall if the 5532 works in that application, and I haven’t found my notes yet for what I was going to do with my cards as far as opamps…you can’t always replace a JFET part like the 455x, TL072, etc. with a 5532. If you have reference of it being successfully done on the 58/MS16 amp cards then go for it. If not you would just want to measure the DC offset at the output of either side of the opamp before and after the replacement, and if the offset significantly increases after the replacement then the 5532 is not suitable. I also like to use the OPA2134, which is also JFET and a good drop-in for parts like the 455x, TL072, etc. If you’re going to change out opamps then I recommend installing good quality machine-pin sockets. I also recommend bypassing the power rails with a small value cap at each opamp to arrest the possibility of the replacement opamp going into oscillation. Be aware not all the opamps on the card are audio path opamps. Resistors…here again, lots and lots of sought after gear is loaded with carbon film resistors. But if you are interested in exploring this, the only resistors I would replace are the ones that are in amplifier stage feedback loops, particularly those with gain. That’s where the noise stemming from the higher thermal coefficient of the carbon film parts will be more prevalent if at all. Lastly, specific to the 58/MS16 cards, the early 58 cards were fitted with polystyrene caps in the feedback loops instead of Mylar or ceramic. You can see this in the 58 parts list. There is a general opinion that the polystyrene caps sound better. YMMV. They are harder to find, more expensive, and more fragile…they don’t handle heat as well such as when being soldered in. It’s interesting to me that in a lot of earlier Teac stuff I see them everywhere in these applications…late 70s and early 80s, but it didn’t take long before they were value engineered out. My 58 cards all have the Polystyrene caps. So that’s something to consider. But probably unnecessary. It’s super valuable to have a spare card you can modify against which you can do A/B comparison to a stock card. And to do mods in stages. That’s how I would approach it because some of this stuff is not likely to be audibly different, and in some case might make it sound worse. I upgraded a bunch of opamps in a couple modules on my early 80s Tascam prototype console…glad I used sockets. I liked the stock channels better. Now, I didn’t know enough at the time to do some analysis to maybe identify why I didn’t like it and if the cause was only 1 or 2 of the upgraded stages…I’d like to experiment some more someday and I have done some since then and like the changes, but my point is don’t assume any change is worthwhile or beneficial. Try stuff. Just position yourself so you can compare. Best thing is to have a buddy switch back and forth when you are doing A/B comparisons so it’s a blind test. It’s super easy to fool ourselves into thinking different is better because we *want* our changes to be magical.
Oh! Last but not least, relays. I’d buy a full set of new relays. Signal passes through them. And if you’re not yet experiencing maddening intermittent signal issues that seem to randomly move from card to card, sometimes follow troubleshooting card swaps and other times not, you will at some point. And relays are typically suspect with that set of symptoms.
I can still post specifics about what my punch list is as far as preventative maintenance and possible part replacements…those are the notes I’m compiling.
I'm going to say that I'd agree with your assessment of Jim Williams' approach. I was asked if I could do some of his mods to a Hohner Clavinet recently and found that, in my opinion, many of them were unnecessary although a few of them were sensible. He was specifying 600V parts in a circuit that only used a 9V supply.
As far as replacing 4558s with 5532s - you need to check the gain of the circuit. 5532s don't like to be used at low gains. A 4558 is just a dual 741 so won't be a FET design but it does have a fairly limited bandwidth so you need to check that the slightly wider bandwidth of the 5532 doesn't cause problems.
That’s interesting…your anecdote with the Clavinet. Did Jim Williams offer any rationale for the use of the 600V part? That seems really strange.
I wasn’t aware the 4558 was just a dual 741. Their slew rate and bandwidth are significantly different among other things. Are you sure about that?
The bandwidth is significantly greater on the 5532 than the 4558, 10MHz vs. 3MHz. At least I’d call that more than a slight difference.
Hey thanks for all this info it’s amazing!!
Just a quick question with the bypass caps on the 5532’s. I’ve ready conflicting things regarding the positioning. Some people have mentioned putting a small value cap from pin 4 to ground and pin 8 to ground ( 2 caps each IC) but I’ve heard conflicting report that putting just one cap across pin 4 and 8 achieves basically the same thing?
Possible parts replacements list would be amazing.
Very interesting about the low value cap and HF. There’s a lot of 47uf electrolytic around the output circuits and on the channel cards as well as 1uf Bipolar caps.
Best practice is to strap each power rail to ground, two caps per device. Strapping the small value cap across the power rails *does* effectively accomplish the same thing, but strapping each to ground is better. I’ve done both, and only do the latter when it’s complicated on the board to strap the caps to the ground trace. Sometimes it’s not easy the way the traces are laid out.
Can you give me the board and part references for the 47uF caps you are talking about C__ on x PCB?
All of the signal path electrolytics on the amp cars are appropriately valued. And even better the circuit is designed with forward bias so they were able to use non-polar caps for all the signal path caps which is better than a polar cap. A majority of the electrolytics on the amp cards are not signal path caps.
I haven't found any justification for the high voltage parts in any of the online discussions. The details are at
The TI data sheet for the 4558 says
The RC4558 device is a dual general-purpose operational amplifier, with each half electrically similar to the μA741, except that offset null capability is not provided.
Thanks @jamesperrett …I was looking at the JRC datasheet…so weird that TI would present the 4558 that way because, at least on paper, the 4558 is advanced spec-wise compared to the 741. But there ya go. Thanks for sharing that. Interesting.
And I’ll take a look at the Clavinet link…also interesting.
Too many interesting things…lol.
So I’m about halfway through this.
Re capping channel cards and output card
New op amps
Adding bypasses to 5532 (just one)
Re capping power supply.
However there are some cap values that are hard to find.
Specifically c35, 36. 0.22uf 50v.
Seems like a pretty low value for an electrolytic. Would using a 1uf change anything too drastically. Just don’t want to wait for parts.
That shouldn’t be a hard part to find…where are you ordering from?
I’d have to analyze whether or not value changes to those would have a negative impact. And you already know how quickly I follow up. I’ll take a look when I can, but 0.22uF is a standard value. Depending on the purpose of the cap you could use another type, but, again, I’d have to look.
New op amps
What caps are you using for the audio path caps?
New op amps
Digikey has at least nine 0.22uF 50V polar electrolytic caps in stock. I didn’t have a lot of time to analyze but C35 & C36 are not audio path caps, it looks like they are in the signal switching circuits on the amp cards, changing the value may effect the time delay with source switching. Again I’d have to look closer at what these two caps do, but since parts are available why not just replace with the stock value?
New op amps
And while I’m answering questions for you can I ask you one? Do you have a resource that affirms the 5532 is a drop-in replacement for the 4558 on the 58/MS16 amp card? I’d like to know if it…would save me the trouble of testing if you know. Or did you measure the DC offset of the 4558 and have you compared to the 5532 once installed?
Hey!!
Regarding audio path caps. I actually did every electrolytic cap in the machine and didn’t alter values just the temp rating I also replaced the Mylar caps with new caps (same values). Felt like if it works it works and I shouldn’t mess with it.
I added some small values across the larger chanel card caps at the back because there Were empty slots for them and figured they probably were just cutting costs.
I managed to find some 0.22uf/50v locally in aus.
Also I have multiple quote from Jim Williams saying he used to use them before “better” chips were made. Also a lot of references that it might cause oscillations so best to use some bypass caps on each chips power.
Haven’t done any metering yet but it powers up fine and I can’t hear any anomalies.
