Tascam MS-16 Help
  • Thread starter Thread starter themaddog
T
themaddog
Rockin' & Rollin'
Hey all,
I finally have a little more spare time and want to start recording on a Tascam MS-16 I purchased last January. I am able to get signal to tape and play back tape, and I think I even have the sync thing down, but here's my problem:
I can't, for the life of me, figure out how to see what the level of the signal I'm processing is before I hit the tape. For instance, if I had a tone playing at 0 db, I can't tell that that is the volume of it until I actually hit the record button (after the corresponding tracks have been armed, of course). I've tried flipping all the switches in every combination I can think of, but I don't have the manual and Tascam has a backorder on the MS-16 docs.
Could anyone give me a step by step detail on how I ought to be able to see the input level before it is actually hitting the tape? I imagine it would also be the same process on this machine as it is the Tascam 58, if any 58 users could help me.
Thanks a lot,
-MD
You should only need to select input to get the input signals to the meters (and also out the output jacks, look out for a feedback loop)
If when you select input as your source you get nothing (and there really is something there) then you have a problem with your deck.
You could check it channel by channel to verify if any fail or work.
Regards, Ethan
Some man pages for you
Thank you very much. I'll try again next time I'm at the studio. These scans should be a huge help.
Thanks a lot,
-MD
Thanks a lot evm,
My problem is the previous owner did a number of modifications to the MS-16. One of these modifications entailed adding a panel of record and sync switches, as well as the output selection, onto the top of a sequencer. This panel was taken from a non-working MS-16. In his modifications, he must have somehow disabled the main panel of switches that are at the bottom of the machine from fully controlling the MS-16. In short, I have to use his modified remote control in order to have full functionality of the machine, which isn't the end of the world.
Thanks again,
-MD
