3
388woes
388 help cont..
Reel,
I had the same problem, only I was not transporting my 388, I just went to press play and it didn't. Sure enough after taking off the bottom panel the belt had come off. I put it back on and it worked again ... for a day, lol. It came off again. I'm wondering if the belt if simply too worn/stretched? (looks fine to me, like new) but who knows? Could there be another reason it keeps coming off all of a sudden? I tried sourcing a new belt to no avail, I'll have to order one from Tascam but before I go and do this I want to make sure all bases are covered and be sure there isn't another reason it keeps coming off.
Thanks for any help,
Dan
A Reel Person said:In that case, I'd suspect the belt has slipped off.
If you raise the RH tension arm, the capstan should spin CCW. If it doesn't, the belt's come off or is defective. The belt may be accessed by removing the bottom panel.![]()
/DA
Reel,
Dan
