evm1024
I've been pondering
I took some time to look over the schematic (A fuzzy schematic really hampers me plus I'm missing some pages) And think about what you have got.
I'm thinking that the +-15 volt supply is being overloaded. I'm thinking that the +15 rail is the one being overloaded (based of fuse discoloration).
I'm thinking that the supply is not overloaded with the channel and DBX cards out but as you add them in the overload increases until thermal runaway happens.
I don't think that the channel cards or DBX cards are the cause (presumes good) but rather the cumulative load is it.
Other cards use +15. I suggest that you pull other cards in the mixer section (or connectors) to get the load down and then try the heatsink heat test with no mixer but with all channel/DBX cards. The idea here is to start at near zero load and add just the channel/DBX cards so as to show the PS can handle their current needs without overloading the PS.
It would be instructive to find out each cards current usage. You could do this a number of ways. One would be to put your meter on amps and insert it in series with the +15 (or +12) rail. THis would require breaking a trace or using some extension cables like Sweets made. Another was would be to remove the (F3) +15 fuse, hook come clips up to the fuse contacts on the fuse board, then connect one clip to the fuse, a new clip to the other end of the fuse which coes to the amp meter (set on AC Amps) and the other probe of the meter goes back to the fuse holder.
PCB----fuse----PCB <----------Before meter
PCB----AmpMeter----fuse----PCB <----------After adding meter in circuit
In short just put an AC ampmeter in series with fuse F3
The idea here is to find out the total current drawn and to then attempt to locate the source of the excessive current draw.
Regards, Ethan
Regards, Ethan
I wasn't expecting that...glad I have spares. Not sure if anything got cooked but I donzt want Cobb damaging things further.
