shadwell157
Hi Guys....first post here
I bought a Tascam 388 today knowing there was a fault. The right hand side/spool struggles to play but if you push the HOLD button it runs fine. So I think the motor could be okay....but something else is up.
I'm a complete novice on this so any ideas would be cool
Also is there anywhere in the UK I can get this fixed/seviced/set up. I'm in suffolk if that makes any difference.
Cheers
Joe
Cheers
Joe
), powered it up, lifted the tension arms with my thumbs, put an index finger over and hit PLAY and then extended that same index finger the other way and gave the takeup reel table a swipe and the table rotates about 180~360 degrees or so...same with the supply side. So it sounds like your brakes are relaeasing properly.
