D
dodgeaspen
I was wondering if anyone has an alignment tape for my Tascam 38 for sale CHEAP. Or is it possible to have someone record a copy for me? Any help with this I would appreciate. Thanks.
A "fake" MRL will not be quite the same as an actual MRL tape, but it might be sufficient for you to do a "fake" mini-alignment. You could set playback levels & do all the bias & record-side alignments, but I'd hesitate to try using that for an actual physical head alignment. Anyway, a fake-MRL might be better than no cal-tape at all. You might want to think about popping the $200-or-so for a real one, in the long run. Good luck.![]()
Thought people would be burning up their keyboards to give their advice and or opinions on my request. I was wrong! So I thought I would post on this thread and read my comments.
You can't copy a legit alignment tape and use it for alignment. Legit tapes are full track. If you copy a full track tape, you end up having to align your machine to the specs of the machine that the tape was copied from and it might not be aligned at all!
You COULD make your machine worse than it already is.
I have 2 "new in box" TSR-8's that I am currently aligning to a new MRL test tape. If I maintain strict alignment tolerances I think the copy will be very accurate especially when you consider it will be used on a very similiar Tascam-38. I am curious to see how well this actually works, If Dodgeaspen still wants to try.
VP![]()
Hi...can anybody helpt me? i just bought a Tascam BR20 and is not sound great on a regulat reel tape...it sound just like there were 2 melodies at once (when playback)...when i record the sound is very good but if i put the record tape on another reel to reel its sound like there were 2 melodies at once? what is the problem? the head's are not calibrated? ther is not a good alignament of the head's? thanks
