Tascam 2488 DAW how do i connect another harddrive?
  • Thread starter Thread starter walters
W
walters
I need more STORAGE space how do i get it on a 2488?
Well, look what the cat drug in, and forgot to cover up.
you go play in medical waste. or alternatively, set yourself on fire.
Check the Tascam Forum.
If you open it up it's very likely the DP01 uses the same Hdrive...just guessing here. But manufacturing inventorys like to use the same part whenever possible and can then buy in greater bulk= cheaper.
Seagate Barracuda have always been well spoken of for being quiet.
Thanks for your response Coolcat.
I'll check the Tascam Forum.
As you say, it's very likely they use the same drive.
Cheers!
I had a friend just put in a different brand in his 2488 and it works.
I guess at 7200rpm, same search time and close specs...its just a HD?
Can i put in a 200g HD drive or something any kind of HD will work???
