"Takes EQ well"...hmmm?
but I wonder at what cost sometimes.
It all depends on what you have and there are good sounding mics for different things and you don't have to be an electronics engineer like me to modify them. Granted, there are a few $30-$50 that would compare with the expensive mics once certain parts are changed out. But there are a lot of mics below $250 that are nice to record with too.
Its hard to find out if the Chinese clones are clones instead of factory 2nds or CCP seizures of stock (which happens) to sell for their war efforts.
There may be a hint here... from what he's saying I'm guessing it may refer to lower Q curves on the frequency response, resulting in less unpleasant surprises when making EQ adjustments.
At the 19:02 mark:
From podcasting to music, nobody needs expensive mics. All you need is to write good music, have interesting things to say and have a decent understanding of audio engineering. And it doesn't hurt to be a good performer.
Success can come with the sole use of an SM57. The vast VAST majority of listeners are not going to care whether or not the sound quality is perfect. It just has to be good enough. Most listeners wouldn't even be able to tell much of a difference anyway. That is the truth of it all.
The only people that care are the people that have been doing it for so long that they can actually hear the fairly meaningless subtleties, and the others are the superstitious - the ones that believe because their favorite artist used mic A, then mic A is a key to success.
And when it comes to a mic that "takes EQ well", that means that it doesn't sound bad when you boost frequencies.
For instance, a microphone can sound absolutely fine without any processing because it is tonally balanced. But let's say you need the recording to sound brighter and you boost the top end appropriately and it then starts sounding bad. That means the mic doesn't take EQ well. There is something lacking in the integrity of the mic's sound.
But there are other mics where you can boost frequencies and it still sounds good.
I was using a vintage U47 the other day. It was past it's prime. Considerably dull sounding. I then boosted the top end to where it sounded balanced but it did not sound good. The top end of that dying mic was not healthy.
So you can think about it like that - a mic that "takes EQ well" is a mic that reproduces a healthy sound across the spectrum.
The ‘takes EQ well’ comment makes sense to me as i have a few mics that don’t. I have a number of mics that i do not like the sound of and EQ rarely seems to make me change my mind. one is the EV RE20, and the other the Sennheiser 609. Both these mics are well loved, but i just dont seem to like them without EQ and struggle to nicen them up. I dont like my 87, its too warm, but you can easily fix it with EQ.
I refuse to buy any tube mic that has holes in the case to expose the glass. If the manufacturer sinks to that level, I question their direction.
CoolCat
Replies
21
Views
785
Slouching Raymond
Slouching Raymond
C
Replies
23
Views
4K
Rodiddley
Rodiddley
