R
RAMI
Guest
Well this track I've already burned em and the guitars are all set.
Wait. If this is the case, then what I said shouldn't apply, unless I'm mis-understanding. If the guitars are "already burned", then the signal and waveform should be the processed guitar + sim. If that's the case, then turning that waveform up and down SHOULD make a difference after all.
The bottom line is that DAWs can be a very personal preference as far as which ones you love, which ones you merely like, which ones you can tolerate if you must, and which ones you absolutely loathe! So once people find a DAW they can figure out how to use, that does what they need it to in the ways that they need it to, and that has a GUI which resonates harmoniously with the colors and vibrations of their auras (or whatever-- I sound like Janice on The Muppets), it's understandable that they aren't going to be much interested in looking at or trying to learn about other DAWs. And even if they'd already looked at a given DAW and found it lacking for one reason or other, it might have changed a good bit since then. Anyway, one person's DAW is another person's dawg.
