First of all, I apologize if the following is addressed somewhere on here, but I could not find exactly what I was looking for by searching the forums.
Anyway, I've got some KRK studio monitors, and there is an audible hum. This seems to be a common problem, and some seem to have fixed it by getting balanced instead of unbalanced cables. I've ordered some balanced cables, since I was in fact using unbalanced. However, I've also heard that where you plug in each monitor matters. I had one plugged into one surge protector hooked to one outlet, and another hooked into another surge protector hooked to another outlet.
So my essential question is: is it likely that plugging both speakers into one surge protector only and getting balanced cables will eliminate the hum? Is this the normal way to do things with monitors? Is there anything else I should know about monitor basics?
