cephus
Slow Children Playing
As a control, I am keeping a string in the packet in my desk drawer and I will put it on my guitar and tune it at the conclusion of the experiment to prove exactly nothing.
I want to thank everybody for their input. In my ongoing research (obsession) I came across this link. It says what I have suspected happens to old strings.
VP
http://www.soundonsound.com/forum/showflat.php?Number=58653
The pitch or frequency of a vibration string is the product of it's mass per unit length and stiffness and the tension in the string? Which of these properties has changed and how?
What is the difference between stiffness and tension and how does that affect pitch?The pitch or frequency of a vibration string is the product of it's mass per unit length and stiffness and the tension in the string?
Does a dirty string have more mass than a clean one? All the crud on my fingers has got to go somewhere, no?
I would think an old string has less mass. Corrosion/oxidation should do this.
lou
lou
I disagree. Old rusty metal weighs less than new clean metal. Rust/oxidation is essentially the same process as fire. As a material rusts/burns it loses mass.If a piece of iron is left untreated it will develop rust, which is iron oxide. The iron has bonded with oxygen, not lost anything, so you'd think it would gain a bit of mass.
That's what I've picked up along the way anyhow. I could be dead flat wrong. I'm real curious now though. I like to know when I'm full of shit.
lou
lou
I never thought of crud adding mass, good point.
VP
lou
VP
Thanks for the explanation. I basically knew that part - although not in such technical detail - but how does stiffness affect pitch given equal tension and mass?Stiffness is ...
lou
More importantly it destroys the uniformity of the strings mass and stiffness per unit length. The same is true of all those dents that fret contact causes as strings wear. Any change in the strings uniformity in these terms will effect the ability of a string to intonate correctly and hold correct pitch. ZB mentioned this earlier if I recall correctly.
I really don't think 'crud adds mass' my most profound contribution to science but regardless, you'd have to measure the mass of each string. Not sure how you'd do that. Triple beam? Highly impractical.
