famous beagle
So, I recorded a bit with five MIDI tracks, using plugs on each track. And everything worked great. Saved it, lights out. The next day, I brought up the project. I went to add to the keyboard track. For some reason, I get a latency of literally about half a second (when normally the latency is not noticeable at all). Then I realize that three of the tracks are giving me this same problem. But the bass and the drum tracks are working fine -- no noticeable latency.
I'm using the same controller, same configuration, etc. from day 1 to day 2.
Any clue?
And tonight, another similar issue has come up. I tracked another tune with 3 MIDI tracks, each using a different plug, again with no problems (same controller and everything as the first tune). Saved it. Tonight, when I pull it up, two of the tracks are working fine, but one track has decided not to play at all. The data is still there, and the meters show movement, but there's no sound from the track. I've checked and double-checked all the plug settings, track volume, mute, etc.
Any ideas?
Thanks
Any clue?
Any ideas?
Thanks
