C
Cndn_Gtr_Guy
I just bought a Washburn Dime36 last night and it came with a gig bag. Is it better to have it leaning against something standing up (with no pressure on the neck) or to lay it down on the floor?
.Dani Pace said:Neither!!! Hang it on the wall, thats why gig bags have that hook thing near the top. Better yet, spend the bucks for a hardshell case, you wont regret it in the long run.
notbradsohner said:you can get a wall hanger for like 11 dollars. They guitar headstock will fit right in it.
No. The weight of the guitar is absolutely trivial compared to the forces of the string tension and the trussrod.Cndn_Gtr_Guy said:Do I need anything special to support the weight of the guitar?
bongolation said:No. The weight of the guitar is absolutely trivial compared to the forces of the string tension and the trussrod.
This is a non-issue. Think about it.
You're correct.gibsonguy09 said:i Dont' think it matters.
When those wall hangers get down to $1.99 -- where they should be -- I'm going to buy a crate of them. They'd change my life. I have thirty-something instruments around here in stands and they take up a terrible amount of space.Hang it on the wall like dani pace said. or get a wall hanger they are pretty cool to
If you lean an instrument against a wall, the additional force on the neck can be measured in mere grams. Lying the guitar down will be only a matter of a couple of pounds on the neck, if that.Cndn_Gtr_Guy said:Not quite sure what you mean....
Yeah, gig bags. What's the point?Idgeit said:I decided to buy a hardshell after I saw a girl standing unknowing on my old bassists bass, while it was in his soft case.
bongolation said:If you lean an instrument against a wall, the additional force on the neck can be measured in mere grams. Lying the guitar down will be only a matter of a couple of pounds on the neck, if that.
The string tension on some of my basses, for example, is well over two hundred (200) pounds, with countering forces in the trussrod. Compared to this, the weight of the instrument is just not significant.
