E
esteban!
i came up with an unusual idea today of how to simulate a soundbooth without paying thousands of dollars (and without having any enclosed structure anyhow). hopefully you guys can just tell me that the idea just plain sucks, or that it might actually work.
i wanted to be able to have a "dead sound" (i guess is the term for removing all reverberation), similarly to a sound booth. i neither have the money or the room for the project, so i came up with this idea (hmm, i guess this is kind of repetitive):
take a 2' x 1' piece of yellow egg foam packaging material (don't know what else to call it). it's that yellow piece of thick foam that has the dimples in it. take that and wrap it into a cylinder. it should end up leaving about a 5 1/2" diameter hole in the middle. i was going to run a beta58a and prop it into the center of the structure (the boom would basically be the support for the entire thing). plug the end of one side of the cylinder with the same foam cylinder. on the other side, attach a pop filter. the vocalist would sing directly inside the structure where the pop filter is and hopefully it would record the desired "dead sound."
i'm not too sure about the sound deadening properties of the said yellow foam, but i would imagine it to be similar to the foam used in real studios, after crude analysis of pictures. so let me know if im just being entirely ridiculous or give me notions of encouragement to undergo this mission. thanks for any comments!
cheers
cheers
