sound only coming out of one speaker during playback
  • Thread starter Thread starter shinemdm
And you can select just the part you want us to see...
1) Press only the Print Screen button (;) @ Wfaraoni)
2) Open Paint and hit Ctrl + V
3) Select the part you want to show us with the select-tool and hit Ctrl + C
4) Select File -> New
5) Select Attributes, and set them to 1x1 (don't worry)
6) Hit Ctrl + V
7) Go File -> Save As -> Whatever filename and choose JPG.
8) Attach it to the post...
and the result may look something like this:
Nice Job Moskus, I learned something here too :D ;) :D
Peace
Bill
alright i figured it out.....here's the image of the mixer
and the tracks screen
and the track properties (if you want any more screenshots then just tell me what)
Is there any control panel software for the SoundMAX card? Can you check in it to make sure you don't have anything panned off centre. If there is nothing special with the SoundMAX card, check using the normal Windows multimedia stuff - just double-click on the speaker icon.... Check both recording and playback settings.
From your tracks screen shot, you should be selecting the input as being LEFT...SOUNDMAX => not stereo.
You current setup is recording a mono input signal - guitar, vox, etc onto a stereo track. So you are getting the signal entirely on the left channel. When you pan this to the right, you are hearing only the empty channel.
Set your input to be LEFT only, re-record a test track and see what you get.
:D Q.
thank yoU!!
Qwerty,
I want to kiss you!!!! its working finally.....thank you so much for all the help.....and to the rest of yall as well who took the time to help me out. thanks again and peace.
max
shinemdm, I tried to tell you, but you wouldn't listen... just check out post nr 3. ;)
