Steenamaroo
Hi all.
I have been given a sony tc-654 to repair for a family member.
The unit works, except it does not give normal output on the right channel.
This applies to tape playback, mic input and line input.
None are audible.
The same problem is noted through line outs and headphone out.
To be truthful, i can hear the slightest trace of signal through the 'non working' output, but it's so faint that it could well just be crosstalk.
i know very little about this sort of gear, but my guess is there's a final output stage that processes audio, whether it comes from the tape, the line in or the mic in?
If this is true, i know what section of the board i'm looking at but i'm a little stuck as to what to do next.
I've put red arrows on the attached image to show where the playback heads connect to the board (one is visually obscured.)
I guess the problem is to the right of where the heads arrive at the board.
Images are at.
www.steenaudio.com/close.jpg
www.steenaudio.com/far.jpg
My first thought was the check all caps in case one is shorting to ground, but i haven't found anything yet.
Can anyone recommend a procedure for testing or speculate as to what the fault could be?
I've tested the wires that pass through the play mechanism. They are fine.
I've also checked the little I/O circuit board. I bypassed it by checking output at the wires/terminals.
Many thanks in advance,
None are audible.
Images are at.
