mark4man
MoonMix Studios
People,
Lately, SONAR XL (2.2) is bogging down with one particular project.
The problem begins when I attempt to open it, which is unusually slow; & the progress bar stops at a few different points (40%, 63%, etc.) While opening the project in question, I kick on XP's System Monitor (with it's Performance Graph.) The CPU Processing Time; & Paging is spiked.
Once opened, I am running 18 to 20 24-Bit, 96 kHz tracks; & I always dropout almost immediately upon hitting Play. I have to hit the Reset & Play buttons a few times before the tracks will play successfully...
...& once they play, they seem to play fine!
I opened the XP System Monitor again during successful playback; & the CPU Processing Speed & Paging are both spiked, with Disk Usage running at about 40%...yet SONAR's meters indicate CPU = 10-15% & Disk = 7-12%...
...which is about normal for 18-20 24-Bit tracks, right?
My ASIO Buffer Size is set to 256 Samples, with ASIO 2.0 Direct Monitoring enabled. I have 2 Buffers in the Playback Que; & the Buffer Size/Mixing Latency is set to Fast, @ 2.7 ms.
My only XP audio performance tweaks are as follows:
Removed Windows Components:
X - Fax Services
X - Indexing Service
X - Management & Monitoring Tools
D - MSN Explorer
X - Other Network File & Print Services
X - Terminal Server
D - Windows Messenger (2)
X = Not activated w/ XP reinstall
D = Removed manually
Disabled Registry Components:
Notification Area [Systray] Balloon Tips
Executed System Tweaks:
Disabled - Fast User Switching
Switched Off - Power Schemes
Switched Off - Hibernation
Activated - DMA on Hard Discs/CD ROMS
Disabled - Automatic Updates
Disabled - Remote Assistance
Disabled - Hide Inactive Icons
Disabled - Automatic Desktop Cleanup Wizard
Disabled - XP Built-In CD Burner
Stopped - Messenger Service
Disabled Services:
None.
Anyone have any ideas?
Thanks very much,
mark4man
X - Fax Services
D - MSN Explorer
X - Terminal Server
Disabled Services:
None.
Thanks very much,
mark4man
