Sonar 2.0 /M-Audio1010/Mackie CR1604-VLZ
  • Thread starter Thread starter malcolm123
malcolm123
malcolm123
From another forum, may have been the wrong one for help. Thanks
Hello All,
Im having a little trouble with the above config. I finally got the mixer to send a signal to the 1010 for seperate ins into Sonar, but I get a delay on all of the lines from the mixer when Im monitoring in the control room. I downloaded the manual for the mixer and says that I should run the direct outs to the sound card, but I cannot get a signal with this setup. The only way I can cet a signal is when I run the 1010 ins from the inserts on the mixer. In other words, if anyone has any help for me, I would appreciate it. I mostly use digital console via Adat or Tdiff and this analog stuff is kicking my butt.
What I really want is to run my XLRs/1/4 inches to the mixer from the instruments / drums etc, then send the signal for each channel to the sound card to track everything in sonar using seperated inputs for each sonar channel.
Help
Thanks
Malcolm
Sorry man,
Been gone for a while. Anyways it's a 1010 and I figured out that the problem was the inserts. If I push them in half way this gets rid of the loop/feedback I was getting.
Thanks
Malcolm
