sweetbeats
Reel deep thoughts...
Not a 58-“OU”...just a “58”
Not much to report on this project, but the 58 is still around...it’s had to take a seat at the back of the bus in light of lots of competing priorities, life, other projects...sleep...anyway, it’s tucked away in the shop. I’ve been going through some serious thinking about all the gear and projects, and occasionally think about stuff maybe I should let go of, but I don’t think the 58 will ever go. It matches my Tascam “M-__” prototype console, and I think will make a good refurb when I get around to it. And here’s an interesting bit of useless information...all through this thread I’ve been referring to my 58 as a “58-OU”. It’s not. It’s just a “58”. I always thought the balanced “OB” and unbalanced “OU” versions of the 58 were introduced simultaneously. Nope. The balanced version came later and when it came to be that’s when the “OU” designation came to be to make the distinction between the two models. So because my 58 is unbalanced I always thought it was an “OU”. I was looking in my manual tonight...doing a little research for another project, and I wanted to look at the schematic for the “In/Out Ampl PCB”, the board that has the input and output balance amps on it. I assumed it would be in my manual because the manual I used to have, which covered the OU and OB models has the technical docs for all the PCB assemblies in it. Makes sense right? So I’m searching and searching in my manual and I can’t find the docs for that PCB assembly. I think “is this manual missing pages after all??” Then I flip to the front, and then start looking through the manual, and there are no pictures or references at all to “58-OU” or “58-OB”...just “58”...like a balanced version doesn’t exist. Then I look in the scanned version of my old manual I had and there’s all the stuff in there about the balanced version, and then also a paragraph at the very beginning I never noticed before, which basically says there was a 58 model that preceded the 58-OU and 58-OB, and it was just call the “58”. I go out to the shop to look at the model/serial number tag on my 58 annnnd:
Yup. Just “58”.
So this is cool and interesting to me. It means I have a very early 58, and the matching manual, which all must be more rare. And the 58 was touted as Tascam’s first balanced multitrack tape machine, but apparently it wasn’t so from the beginning, which explains why the balance amp board and it’s power supply seem a little kludged into the 58 chassis...the fact there is a separate power supply is a dead-giveaway it all came later. In a way it almost kind of makes my 58 an even better match for my prototype console...they would have likely been made in the same year.
Yup. Just “58”.
